whats leaking?
Old Jul 12, 2010 | 07:16 PM
kenward's Avatar
kenward
Default whats leaking?
1,500 miles ago I changed the primary oil, then a week ago I noticed a drop on my garage floor so I tightend the primary drain plug a little more. I havent noticed any more on the floor but after wiping it down and riding several times I noticed its still leaking every time I ride it just not enough to drip on the floor. Almost looks like its coming from the front drive sprocket but its so hard to tell. All three oils are similar so its hard to tell that way almost seems a bit redish and there is redline in the tranny. I gues I should drain the primary and replace the O ring on the plug again and see where that gets me. Dam always sumpthin. Any suggestions?
Old Jul 12, 2010 | 07:24 PM
JRK5892's Avatar
JRK5892
could be o ring could be shifter shaft seal.. if it is off your trans check the plug on that as well could be run down
Old Jul 12, 2010 | 08:32 PM
thedonthere's Avatar
thedonthere
maybe it's the shocks
Old Jul 12, 2010 | 10:08 PM
08fxdf43202's Avatar
08fxdf43202
I've messed up the 'O' ring before by over tightening the plug.
Old Jul 13, 2010 | 07:20 AM
kenward's Avatar
kenward
Good one Don!! I will rotate the shocks to see if the same thing occurs on the other side.
Rickr01
Aug 22, 2012 10:03 AM
stbobshadow
Jun 27, 2012 01:45 PM
Streets of Fire
Oct 29, 2008 08:21 AM
oldroadie
EVO
16
Sep 15, 2008 11:14 AM
Canuck HD
May 12, 2007 03:19 PM
