expert advise needed
what size(Thickness) head gasket should i use on my SE big bore kit 95". iam converting my 06 dyna tc 88 to 95" with SE jugs and SE high performance heads. i want to use SE perfect fit push rods and the high tinsel strenth cylinder studs. Will it be all right to use the SE high performance gasket and still be able to use the perfect fit push rods.
I don't know what thicknesses they offer, but I think you can alter your compression ratios a little depending on what you're targeting. I guess a thinner gasket would cause a sliiiightly higher CR when the piston forces the mixture into that sliiiightly smaller space.
For the flattops, it's a bit overkill, but you can......
Use the Cometic .030 or the SE Head gaskets (Steel Laminate)......
Both are very good quality and durability......
Just remember to torque in the proper sequence (3 steps), and break them loose and do it again.....
Failure to do so will result in loosened headbolt caps and possible damage to your motor.....
And yes, the P-F pushrods will work.....
