How thick are SE head gaskets?
Old Nov 20, 2008 | 07:16 PM
TODDNVAL's Avatar
TODDNVAL
Default How thick are SE head gaskets?
Does anyone know the thickness of the SE 103 head gaskets? I assume they are thicker than the cometic .030's.
Old Nov 20, 2008 | 07:36 PM
Biggzed's Avatar
Biggzed
I believe they are .042, but check with Dawg. He can probably find out for sure.
Zach
Old Nov 20, 2008 | 07:41 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
.040...... If your looking at using a .030 you better calculate compression ratio....if someone can give me a REAL cc volumn of the TC96 cylinder heads I will...and base it on a few piston sizes ...along with the difference using a .030 to .040 gasket. I have some numbers on the inadquate HD quality control on how far the pistons are down in the cylinder bores, DA's.
Old Nov 21, 2008 | 06:49 AM
TODDNVAL's Avatar
TODDNVAL
Thanks guys, I was looking at .030's but decided it would be pushing me on the comp with my cam choice.
Old Nov 21, 2008 | 08:20 AM
Junebug's Avatar
Junebug
You can get the cometic gaskets in .040 also. I am pretty sure the stock 96 heads are 92cc's.
PTSDBob
Engine Mechanical Topics
Mar 9, 2015 06:23 AM
troop
Feb 19, 2010 05:23 PM
tony2772
Exhaust System Topics
Apr 8, 2009 10:43 PM
XTrooper3936
Apr 3, 2009 05:12 AM
EdboIllinois
Mar 19, 2008 10:15 PM
