Extension Kits
Hi all
I am a tall guy 6'6" 240 lbs and I ride a 09 DYNA Fat Bob with forward controls. I have put a TallBoy seat on and I am now considering extensions. I found these http://www.kuryakyn.com/index.cfm/go...ID/23/IMID/230
Kuryakyn makes pretty good stuff, what is anyone else doing for extension kits?
Hi all
I have a lot of other Kuryakyn parts on my bike and the fit and finish is always very nice. My only complaint is that the chrome fasteners are too often not up to par. I don't know what grade they are, but some are very very weak, way weaker than even a grade 3 bolt. Even the cotter pins that they supply are about two sizes too thin.
Kuryakyn advises to use their anti-seize lube on all fasteners, then barely gives you enough. Make sure to use it, or use your own. Even after using anti-seize, I still snapped off two bolts just trying to remove them a month later to make a change. Those bolts were just chromed junk metal.
Otherwise, I like Kuryakyn products a lot and plan to buy more in the future.
The extension kit is on back order until mid sept.
The tallboy seat is good, it did add room however more will be better. Plus it is better for a passenger
