Need serious help....
Old Jan 21, 2011 | 07:35 PM
prouddawg's Avatar
prouddawg
Default Need serious help....
with bleeding brakes lines. I just changed bars and all and cant get brakes to get pressure on front. Have fluid in line but no pressure
Old Jan 21, 2011 | 07:41 PM
Gwjvw's Avatar
Gwjvw
It takes a few. Just pump and pump and release fluid ,,,,,then pump while not releasing the little fitting and you will see air bubbles come up then after a while bleed again untill all is good!
I felt the same way,,it wasnt working then all of a sudden,,,, Bam! Atleast that how it went for me :-)
Old Jan 21, 2011 | 07:53 PM
1skrewsloose's Avatar
1skrewsloose
I've had good results using speedbleeders.
Old Jan 21, 2011 | 08:02 PM
Iceman24's Avatar
Iceman24
Once you've topped off reservoir:
1. Pump the brake lever to build pressure.
2. While holding lever, open bleeder valve (~3/4 turn).
3. Close valve once loss of pressure is felt.
4. Let lever return to released position.
5. Repeat add/pump/bleed/release until bubbles are gone & steady fluid.
6. Tighten bleeder valve 80-100 in-lb.
7. Top-off reservoir, if needed.
Hope this does the trick...
Old Jan 21, 2011 | 08:33 PM
DCLXVI's Avatar
DCLXVI
Speed bleeders help. On front brakes I prefer to reverse bleed them. For me it's easier because air likes to go up. I use a syringe with a short piece of hose and just force it up. There is no need to squeeze the lever while using this method. When you are done just tighten the fitting and that's it.
Old Jan 21, 2011 | 11:11 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Keep at it. The last time I did my brakes it felt like it took forever to get it.
Old Jan 22, 2011 | 01:34 AM
leepetersusn's Avatar
leepetersusn
It took a loooooong time when I did mine a few weeks ago. Something like 30-45 minutes, but when pressure started coming on, it came on quick. I was starting to get discouraged as well, but read some posts on here that it takes a while, so I just kept at it.
Old Jan 22, 2011 | 02:07 AM
mccalljv's Avatar
mccalljv
Helped a friend change out and had the same issue, thought it wasn't working, then all of a sudden it worked. Took two beers each...
Old Jan 22, 2011 | 05:54 AM
nkauf21's Avatar
nkauf21
I had problems when I did mine to. What helped me was turning my wheel all the way to the left and when I opened the bleeder a huge air bubble came out and they built up pressure after that.
Old Jan 22, 2011 | 06:35 AM
kpolak's Avatar
kpolak
There is air in the line.
Try wrapping the bleeder fitting threads with teflon tape, and bleeding the brake again. That shoud stop the air from entering thru the threads around the fitting.
I gave up before I learned this trick, and went to a brake bleeder vacuum pump.
