Need serious help....
Old Jan 22, 2011 | 08:43 AM
rjsimmons's Avatar
rjsimmons
Just changed the front line on my WG from OEM to braided stainless. First time ever for me bleeding brakes. The process was slow but I was able to get the proper pressure. Make sure you are adding fluid to the reservoir so as to prevent any air getting into the line. I let gravity take the majority of the fluid through the line and then siphoned from the caliper end until the new fluid was coming out. Then did the: Squeeze Open Close Release method mentioned previously.
Don't give up!
Old Jan 22, 2011 | 08:52 AM
hell hound's Avatar
hell hound
i used a small vaccuum pump on the bleeder and it works great. 20 bucks at auto zone.
Old Jan 22, 2011 | 09:00 AM
JRK5892's Avatar
JRK5892
you need to bench bleed the system man, run your brake hose into your resivor and pump till you get fluid out of the hose, so it is basicly pumping fluid back into itself... this is a bench bleed...
then hook it up to the caliper and bleed the rest of the way... are you useing a mighty vac or anything? i used speed bleeders as well...
let me know if you have any questions i fight with brakes alot
Old Jan 22, 2011 | 10:59 AM
Sharknose's Avatar
Sharknose
Originally Posted by 1skrewsloose
I've had good results using speedbleeders.
+1. And so will you. Otherwise, if you're going to do it the old school way without a gizmo form the parts store, it really helps to have an assistant. One of you works the brake lever, the other opens/closes the bleed bolt. Trying to do both by yourself will make you crazy.
Old Jan 22, 2011 | 11:21 PM
prouddawg's Avatar
prouddawg
Default I finally got them bled.
I had to go to auto zone and buy the vacumn thingy majiggy!!! It worked but dan it still took several hours. But it worked and I was on the road today!!!!
Old Jan 23, 2011 | 08:38 AM
hell hound's Avatar
hell hound
glad to here you got it done
Old Jan 23, 2011 | 08:54 AM
cmvsm's Avatar
cmvsm
I bought the speedbleeders and didn't do a whole lot for me. They are still on the bike for another try down the road, but I bought a bleeder pump system from Harbor Freight for $20, and it took me literally 10 mins to bleed.
If you want to ensure that all bubbles are out of the system, tie your brake handle back with a bunjee cord overnight. When you release in the morning, not uncommon to get another 1/4 pull of rock solid tightness in the handle.
harley7316
Sep 18, 2014 12:15 PM
JDavis187
Jul 16, 2014 01:32 PM
rcmty
Jun 18, 2011 09:28 AM
sp9997
May 2, 2010 10:06 AM
Naz_Man
Sep 1, 2006 08:38 PM
