I screwed up!
Mad and depressed!!! Donnie
This is no big deal. All you need do is gently tap the brake fluid resevoir with a platic screwdriver handle to work to bubbles out of the cylinder. I had the same trouble and got this tip from someone here, and it worked flawlessly.
Chuck
you do not need a bleeder pump??
bled the lines on my softail
open the bleeder depress the brake and hold. close the bleeder and repeat.
Hummmm maybe I was doing it wrong... I'll try your way tomorrow. Thanks Donnie
I got a new braided brake line so I decided to go ahead and put her on. I tell you I learn something new with my Harley every day! No bleeding like a car as I was told.. NO!! You need a bleeder pump? OMG I had no idea and now I have no front brakes. I was out there pumping and pumping and still no pressure, release, tighten and pump pump still nothing, call a friend and hes says you need a bleeder pump.... dang it!!! How much is that going to cost me now?
1. remove master cylinder cover.
2. tap master cylinder with a plastic screwdriver handle in the area where the brake line attaches, and watch the bubbles rise. When they stop, then...
3. go through a bleeding cycle, and repeat this sequence from step 1.
Chuck
Whiff
