Differnces between '05 and '06 exhaust?
Old Oct 8, 2006 | 05:01 PM
Gilby's Avatar
Gilby
Default Differnces between '05 and '06 exhaust?
Are there any differences between exhaust systems for '05 and '06 dyns other then the holes for 02 sensors? I ask because I have a PCIII with o2 eliminators and would like to purchase pipes without the holes if they are compatible.
Old Oct 8, 2006 | 05:25 PM
Pippeis's Avatar
Pippeis
Default RE: Differnces between '05 and '06 exhaust?
no differences
ciao...
F
Old Oct 8, 2006 | 07:06 PM
redheadfred's Avatar
redheadfred
I bought 05 bassani pro streets for my 06 bob , had to do some trim work on the rear bracket they sent . Other than that everything bolted up good . The pc3 is a good mod , you'll def like it .
Old Oct 8, 2006 | 07:18 PM
bobcowan's Avatar
bobcowan
The oil filler is in a differant spot. Be carefull about pipes that may have a tube over that area.
Old Oct 14, 2006 | 05:41 AM
Gilby's Avatar
Gilby
Thanks guys, picked up some v&h shortshots off ebay, they just got here today, will be going on the bike on sunday.
Old Oct 16, 2006 | 03:53 AM
Gilby's Avatar
Gilby
Just finished installing the pipes and test riding, sound great. bobcowan was right about the oil filler spot, the rear pipe goes right over it, and in fact is resting on the cap. do you guys see any problems with this? I didnt think much about it first but now I'm starting to worry the heat will transfer through the cap and melt the plastic dipstick. Probably just being paranoid, but what do you guys think?
Old Oct 17, 2006 | 10:55 AM
The Punisher's Avatar
The Punisher
I'm thinking your gonna have to remove your rear pipe everytime you change your oil or to check your oil level???[:@]
Old Oct 17, 2006 | 02:05 PM
Gilby's Avatar
Gilby
yeah but its not that big of a deal to me. I just want to be sure that there will be no problems running an exhaust pipe that comes in contact with my oil filler cap
Old Oct 17, 2006 | 02:25 PM
dog06bob's Avatar
dog06bob
I probably be concerned.
Old Oct 17, 2006 | 10:00 PM
Gilby's Avatar
Gilby
What if I throw a couple washers between the mounting plate and the pipe to raise it off the oil cap, Any dangers of just running it close like that? I've put over 150 miles on these pipes in the last couple days and everything seems fine so far.
