LED Fuel Gauge help?
Old Mar 11, 2011 | 01:19 AM
IrishRedneck86's Avatar
IrishRedneck86
5th Gear
Default LED Fuel Gauge help?
Hey guys wanting a little info on the LED Fuel gauges.
1 Has anyone delt with them?
2 How easy are they to read out in the bright sun?
3 Are they easy to install yourself?
Because I am currently looking at the Skull LED Fuel Gauge to put on my 03 Lowrider
Old Mar 11, 2011 | 01:46 AM
'10 Wide Glide's Avatar
'10 Wide Glide
I installed mine they are the flush mount ones they are very easy to install with the instructions that come with the gauges.
They are easy to see in the day time.
But I do have a friend that has the scull's on his bike and they are just bright too.
Old Mar 11, 2011 | 08:47 AM
JRK5892's Avatar
JRK5892
wide glide do you have a copy of those directions? i just got a set of flush mount guages i won on ebay... they are in crap condition i had to heat the rings up to 350 for 20 min to try and shape them back, i got ripped off... but i am trying to save them, any directions you have would be plush!
Old Mar 11, 2011 | 09:11 AM
'10 Wide Glide
I don't know why I cant load a pdf file right now but I have a link to where you can download the instructions from.
http://www.harley-davidson.com/gma/g...8&default=none
Old Mar 11, 2011 | 09:17 AM
red devil's Avatar
red devil
I got the HD skull led gauge on mine, it's a pretty easy install. It comes with step by step instructions. The hardest part is getting the wires back into the clip under the tank.
Old Mar 11, 2011 | 09:23 AM
JRK5892's Avatar
JRK5892
thank you
Old Mar 11, 2011 | 09:27 AM
'10 Wide Glide
I think that was the hardest part for me as well
Old Mar 11, 2011 | 09:28 AM
'10 Wide Glide
Originally Posted by JRK5892
thank you
No worries
Old Mar 11, 2011 | 10:23 AM
slider1156's Avatar
slider1156
Take the front bolt out of the tank and block it up with block of wood. Then you can get your hand in there to do the wiring. Easy to install, works ok. Once in a while I have a led go out but it always comes back on. So far
Old Mar 11, 2011 | 02:26 PM
IrishRedneck86
5th Gear
Thanks for the info guys I def think I will pick up the Skull fuel gauge to go on the bike and compliment my Skull fuel cap.
Schwanz583
Jul 21, 2011 05:32 PM
e1doug
General Topics/Tech Tips
Apr 30, 2009 06:05 PM
whistler2000
Jul 27, 2008 08:59 PM
doghog
Jul 1, 2008 11:21 AM
jd_underdog
May 2, 2008 03:08 PM
