How do you check your spoke torque/tightness?
Here is a link to instructions for spoke torqueing.
http://www.fasstco.com/technical/tut...sting-tutorial
That's because torque wrenches are designed to be used so that the bolt )or in this case spoke) is moving at the time the specified torque is reached. There is a difference between static and dynamic force on a fastener, largely due to friction. Placing a torque wrench on a fastener (spoke, bolt, etc), applying force to the wrench and hearing it click if the spoke is not moving is not an accurate verification of torque. Fasteners must be moving at the time the required torque is indicated on the wrench or else you may be generating a false positive.
As for the statement of tightening the spoke because they are loose and pulling the wheel out of tru... that's BS... the spoke is loose.. if the wheel was true when the spoke was tight... then putting the spoke back to torque specs when the wheel was tru, does not pull the wheel out of tru.
Having said that, you DO want to check the rest of your spokes for proper torque... which is actually really checking the tension... because spokes don't get loose by the nipple rotating, they get loose by stretching.
The ting-ting-tong method, is a good 'kick the tires and light the fires' type of check before you head off in the morning on a run... but it is something to pay attention to... the lower the 'tong' tone, the looser the spoke is... and you need to have it checked as soon as possible.
If you are going to mess with your spoked rims... get yourself a truing stand and a spoke torque wrench
"ting, ting, ting, tong, tong, ting, ting, ting, tong".....
"Ting" is good, "tong" is bad, the wheels don't really go out of true much once built, just check the tension every 4-5,000 miles and you'll be right.
Takes a lot to pull them out of true once the tyre is inflated.
Wheel truing is almost more "art" than science. Wheel builders have my respect. I remember doing my first wheel on my BMX bicycle, back in the early 1970's. It required patience and know how. 2 things I lacked. I ended up with a pretzel.
