dakota digital head temp readings
Sorry to hijack the thread, but I am thinking of picking one of these up. There is no tach on the street bob from the factory so my question is: If I buy one of these is there something I need to install for the tach function to work or is it just plug and play for all functions. Thanks in advance.
well i chime in here just to bring back a dead thread,
I believe correct operating temps for the head is around 300F mine runs about 305F scared the crap out of me for a while I thought that was the oil, I also have a Jagg oil cooler but I need to do some work on my tune I believe.
I also need to get a oil temp gauage setup just to check it may have to get the HD one.
PS I live in Austrilia so most dyas its either hot or dam hot, if you know what I mean.
Since you brought this back from the dead I'll chime in, at least on the head temps. I'm using Harleydroid and my head temps show between 240-285 when rolling depending on the outside temp. If it let it sit and idle for 5 minutes or so it will jump up to around 315. I was running XIEDs, which helped, and now running the Dobeck Gen 3 instead which helped a little more. Without either of these the temps were higher than above and scared the **** out of me when I first saw them.
