VO2 air intake and slip on mufflers
Hi guys, New to the forums. I have a 2010 dyna superglide FXD . I added Vance and Hines 3" slip-on mufflers and would like to add a Vance and Hines VO2 intake . Do I need to add a fuel mgmt system such as Fuelpak or will the bikes computer make the proper adjustments. Any help is appreciated.
Yeah, It needs to be tuned...I got just pipes first and it ran fine, not great and then I added a high flow air cleaner....yeah it needs to be tuned runs pretty much like crap. Just haven't had the scratch to buy a tuner(was also hoping the stories of the 20% adjustment were true, definitely not true in my case). Hopefully I will have enough in the next couple of days, as it has limited my riding time. For reference I have a 2011 Street Bob.
Welcome to the forum.
We need a smiley of someone opening a can of worms .
There are some very knowledgeable people saying that you don't actually need to retune for stage-1 on the newer bikes, since about 2007. The Delphi system being capable of adjusting for that much extra flow. Take a look at http://www.nightrider.com/parts/ied_faq.htm for instance.
Having said that, these bikes run lean from the factory for EPA compliance. Sticking on pipes and an A/C and leaving the tune stock is not going to get the best out of that new hardware and the bike will run hot.
I think the least you should do is fit some Xieds and, preferably, fit a proper fuelling solution such as a SEPST.
I have to agree with foxster on this one...You can pick up XEID's for 100 bucks if your are on a budget and it will give you the fuel you need and you can install yourself in less then 15 minutes.
I would check out nightrider.com just to get a lot more information on the questions you have, very informative site. Don't hesitate to call the owner as he likes to share his knowledge. He will actually steer you away fron his products if it's not right for you.
And you don't NEED a tuner, but even if you do nothing, you have to deal with the lean condition. My bike ran very hot and surged right off of the showroom floor.
Need is the key word, no you do not NEED one, but your bike would benefit from one.
It will do the adjustments to keep the stock profile, but to get the most out of it you would want a tuner.
I then took the bike to Jim's Cycle Shop in Axtel, TX and had it dyno tested. He showed gave me the print out and pointed out that it is right on the money and that I didn't need a tuner.
