I Need To Tighten the Steering Head...
Old Oct 4, 2016 | 12:42 AM
rogersachs's Avatar
rogersachs
Dr. V.,
Please see my post today to Ride. It worked well for me. I came up with the same idea. Good thinking. I also wished there was a zerk. Is there any reason that some one could drill and tap a fitting.
Roger
Old Oct 4, 2016 | 12:47 AM
JustOneDean's Avatar
JustOneDean
Originally Posted by 08fxdf43202
I'm not sure how an 05 is configured...
On my 08 I losen the top nut till it's hanging on by a couple threads. Then I losen the UPPER tree pinch bolts & pull the handel bars up, which pulls the top tree up & away from the star nut.
I'm then able to tighten/losen the front fork stem bearings, slide the top tree back into place, tighten the top nut - then the pinch bolts and preform the 'fall away' test as per the service manual.
You need to loosen the lower tree pinch bolts. The preload on the bearings comes from how snug the lower tree is on the steering head. The adjuster moves the tree up or down on the fork tubes. If the pinch bolts on the tree are torqued, it won't be able to move. If you're performing the fallaway test as the per the service manual for an '08 FXDF, you'll see that the adjustment procedure calls for loosening the lower pinch bolts before adjusting the star nut.
pistole
EVO
Apr 19, 2013 04:30 PM
crepe
Jun 25, 2010 05:43 PM
schwangster
Apr 4, 2009 01:00 PM
icecaps
Mar 12, 2009 06:04 PM
jsbridgew
Dec 26, 2007 06:15 PM
