Rear Turn Signal Removal From Housing With Out Cutting Wires?.
Old 03-21-2014, 11:28 PM
DirtinLa's Avatar
DirtinLa
DirtinLa is offline
6th Gear
thank you
DirtinLa's Avatar
DirtinLa
DirtinLa is offline
6th Gear
BTW I made the puller tool out of coat hanger wire and hooked the ends just a little.
Old 05-04-2018, 08:13 PM
Red5standingby's Avatar
Red5standingby
Red5standingby is offline
Stage III
Default broken wire connector
Hey FXD2003Rider, any idea where you can get a replacement connector for that black wire? I pulled too hard with the pliers before I was able to depress the tang and the copper strands broke. I pulled the connector out of the reflector housing afterward, but haven't been able to get it open so I can get the old copper out and feed the newly skinned copper back through. It'd be helpful to find a new connector. I have a 2010 Sportster 48, but the connector style looks identical to your photo. Thanks in advance.
Old 05-05-2018, 03:42 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
It's not mentioned in the parts catalog.
You could try the H-D dealer or take the old one with you to an auto parts store. Try Google for spade cable connector is and option as well.
Old 05-14-2018, 02:15 AM
Red5standingby
Stage III
Will do. Thanks!
19jake91
01-03-2018 04:00 AM
DeathProof72
02-02-2011 08:34 PM
yoseppi
09-01-2008 12:22 PM
yoseppi
08-21-2008 04:37 PM
OneBlackFly
01-13-2007 07:45 PM
Quick Reply: Rear Turn Signal Removal From Housing With Out Cutting Wires?.
