Rear Turn Signal Removal From Housing With Out Cutting Wires?.
Tools I used to open the turn signal housing:
- coin to take off the lens
- my home made extraction tool
- 4 mm blade flat blade screw driver to feed the grommet into the housing
Step 1:
Take off the lens using a coin wrapped in a piece of paper tissue
Step 2:
Use the extraction tool to pull out the socket assembly
Step 3:
Take the screw driver to push the vulcanised grommet into the housing and feed the wires:
Step 4:
Pull out the socket assembly :
Step 5:
Use the screw driver to push in the (driving light) connector's retainer tab and pull out the connector (don't forget to lift up the tab when re-installing the connector into the assembly):
Step 6:
Feed the wires and pull out the turn signal contact seating:
Step 7:
Slide back the turn signal contact seating and notice how the contacts are crimped onto the wires:
When I mounted the aux lights to my Dyna
I had to feed and route the turn signal wiring inside the aux lights. I cut off the metal contacts, routed the wiring and re-soldered them onto the wires.....
