Switchback Bag Fell Off!
Old Jul 10, 2012 | 03:57 PM
BullK9's Avatar
BullK9
That sucks man...
Old Jul 10, 2012 | 05:10 PM
craig11dyna's Avatar
craig11dyna
What are you going to do about the chrome piece with the lock?
Old Jul 11, 2012 | 03:42 PM
FLD4sure's Avatar
FLD4sure
The lock is fine just scratched, so I took the resin and filled in the scratches, sanded as smooth as I could, and painted with plasti dip.
If it doesn't look good I might just put the reflective tape trim over the scratched areas.
I should be able to have it finished this week and I'll post some pics.
There is a nut behind the lock that holds it on and I noticed that both bags were getting loose, so I put lock tite on them - all Switchback riders might check yours too so the lock doesn't fall out of the mount.
Bill
Phoenix,AZ
Old Jul 11, 2012 | 09:40 PM
perryross's Avatar
perryross
"There is a nut behind the lock that holds it on and I noticed that both bags were getting loose, so I put lock tite on them - all Switchback riders might check yours too so the lock doesn't fall out of the mount."
Thanks for the heads up.
Old Jul 12, 2012 | 06:09 AM
cecharles's Avatar
cecharles
Good point Perry, I'll go out at lunch time and check mine out.
Old Jul 12, 2012 | 03:14 PM
FLD4sure's Avatar
FLD4sure
Just remove either set of 2 screws on the canvas part and you'll have access to the back of the lock.
Mine started getting a little loose, so like I said, tighten that nut and a little lock tite too. (might as well tighten everything while you're there)
The frequent locking and unlocking with the key loosens it up I'm sure.
Bill
Phoenix,AZ
Old Jul 14, 2012 | 05:40 PM
FLD4sure's Avatar
FLD4sure
Default Bag Fixed - Bagger Again!
OK, if anyone is interested I fixed my bag and have "switched back" to bagger riding. Have to admit, I kind of missed my bags.
It's not a perfect cosmetic fix but cost about $50 and I added a little more night safety visibility too.
The reflective tape is very faint in the daytime and very visible at night.
Bill
Phoenix,AZ
Old Jul 16, 2012 | 02:07 PM
craig11dyna
I like the flames on the bottom of the bags. The shot from the back lots cool.
Old Jul 17, 2012 | 05:26 AM
cecharles's Avatar
cecharles
Looks great man!!!
Old Mar 16, 2013 | 10:03 AM
jacobopty's Avatar
jacobopty
Stage I
easy cheap solution: I use heavy-duty cable ties 24" (black) and secure the bag to the top of the back shock absorber. This is from the side to the bike so its kind of hidden from view.
cost 6.25$. Have to carry a cable cut plyer to remove the bag and extra tie wraps.
