Should I get a crankcase breather?
Ok, so my uncle has been giving me advice on building my streetbob, he is now suggesting a crank case breather kit...his theory is that oil should be differentiated from fuel and air mixture.
I hear that the v-twin is a internal breathing engine, you may need one if you're running on a flat head or possibly an evo engine, but on an '09 v-twin it's a waste of money.
Any thoughts or comments? and if it is a good idea to spring for one, what brand is good as well as the extra parts needed?
If I am wrong my feelings will not be hurt so be as blunt as possible!
Do you mean rather than feeding the head breathers into the air cleaner to take them off somewhere like to the road, a catchcan or a filter?
If so, then it depends on the age of the bike and how much you get out the breathers. If the bike is fairly old and slobbers a bit then you probably don't want that into the carb/throttle-body. If its a newer bike (<20K miles?) then I'd not worry about it.
Sorry about not giving spec's,
It's an 09 street bob, 4000 miles, and i have a screaming eagle (circle) air cleaner. the rubber breather hoses coming from the heads puts oil into the throttle body.
is crank case venting good for longevity? (not prone to crack under pressure)
And is the oil ok going into the throttle body?
Received 3,955 Likes
You bike will run fine how it is, however it will run better if you route the hot oily air from the heads to the atmosphere.
All internal combustion engines like cool dry air going into the intake, and the stock set up is EPA compliant by routing that hot oily air into the intake, which reduces performance and can lead to carbon build-up (reduced engine longevity).
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
Savage223
Oil Archive (no new posts)
06-06-2011 07:39 PM
