shuts off
i have 07 superglide when slowing down and coming to a stop the bike will idle down and shut off. it will start back up but with the same results
i checked ground wires, bty wires etc cam anyone help
the only mods on the bike are screamin eagle slip ons and boyesen xwing. the bike has 20,000 kms purchased in ontario drove to newfoundland with no probs. installed boyesen xwing approx 1500 kms ago
like nevil said clean the throttle body and the idle air control valve. They can get sticky and then the stepper motor will not work in the air valve. I always put a rag past the throttle blade to catch the crap from washing the throttle body. I don't want that crap going down the intake, but don't forget to pull the rag out!!!!
Is your ECM throwing any codes? If you have code thrown, when you start the bike your check engine light will either come back on after 4 seconds, or stay on longer than 8.
Your IAC valve will reset at engine power off... that's what is happening between your 'switch off' and the running lights blinking after about 10 sec.
I would also check for vacuum leaks... etc, anything that will knock your idle down anyway.
Does your bike idle okay when just sitting, or at first startup?
