shuts off
Old Aug 1, 2012 | 01:29 AM
cfi's Avatar
cfi
Mine did the same thing... cleaned the IAC and problem solved.
Old Aug 1, 2012 | 02:32 AM
fat bastard 68's Avatar
fat bastard 68
Hi Guys,
My bike has cut on me a few times while riding, I'd pull over and get it to start. I've got P1351 and P1354 codes coming up. Anyway bike is at home now it won't start the light comes on but I can't hear the whirring sound that you wait for to stop before cranking the bike
I hoping it's just a starter relay fuse
Any ideas ?
Old Aug 1, 2012 | 05:39 AM
peter deering's Avatar
peter deering
thanks willl check all the above mentioned
Old Aug 1, 2012 | 02:45 PM
peter deering
Tks guys had my buddy clean the IAC and throttle body seeems to be running better, also put a fuel additive by a company sea foam which is sensor friendly. He said to use additive on a couple of tanks and will clean out fuel injectors. he uses this additive in all his fuel and has no probs. he rides a street glide. Seems to be a common prob. He figures to be the fuel here in the area. Tks again guys and keep the wheels between the ditches Later Peter D
Old Aug 1, 2012 | 11:31 PM
archergodwin's Avatar
archergodwin
Originally Posted by fat bastard 68
Hi Guys,
Any ideas ?
A. Those are ignition coil codes, front and rear, open/low. Check your wiring.
B. The 'whirring' is your fuel pump.... check your wiring/fuses.
C. Apologize to Peter for trying to hijack his thread...
Old Aug 2, 2012 | 01:09 AM
cfi's Avatar
cfi
That Sea Foam is great stuff. I've used it my dirtbikes and sleds for years. I use it in my diesel truck too.
Old Aug 2, 2012 | 04:44 AM
maddghost's Avatar
maddghost
With nevil and the others on that, although one other guy ended up haveing to change his crank position sensor.
Old Aug 2, 2012 | 07:01 AM
fat bastard 68
A. Sorry Peter!
I did end up starting my own thread.
I just put in a new relay and starter fuse , bike started, gonna take it for a spin
Old Aug 2, 2012 | 08:57 AM
peter deering
no prob guys its great to have a good forum to discuss probs, especially when your as green with mechanics as i am. If prob persists my friend said to bring my bike back and check it again, hopefully prob is fixed Later Peter
Old Aug 2, 2012 | 02:41 PM
peter deering
Tokk my bike for a s200 plu km ru today no probs tks again Peter
Guzzi
Oct 22, 2018 04:22 PM
youngr3
Nov 20, 2013 07:30 PM
PastorToddAK
Jul 6, 2012 05:52 PM
sastrac
May 12, 2008 08:48 PM
murf1
Jun 25, 2007 08:55 PM
