Way to go. It's great to work on these. Several years back i bought an Edelbrock engine kit that was cams, heads, pistons, and remap cd. it sat in my garage for a year because i never could find some one that I trusted and also scared they were going to gouge me. I finally took it on after a year of studying service manual and stuff. All along worrying I was destroying my low rider. I've put about 10k miles on it and it runs just right and I figure I just rebuild it every 10 years and keep it forever. It's liberating and they really are simple to work on. By the way, I had to grind my cases out a bit to make room for my really high lift cams. She sounds really good...
I see that you put in a SE204 - I also put that cam in about a year ago. I runs pretty good for a DIY project but I do have a slight ping sometimes when I really crack the throttle. I see that you used a PV - did you use a custom timing table? If so could you share it (so I could compare).
Thanks & BTW nice post - good to learn from others experiences.
Jimmie
Glad you like the post! I don't have the PV nearby at the moment, but will get it tomorrow and post it.
I did a lot of research on the cams and decided to go with the SE204. They seemed to match my riding style. Others may be better, but I got these new for $80 on eBay. It's hard to overlook the difference in price.
Dang, $80? I would've gone with those cams too. Good job on the install.
I did mine myself also...whole kit n caboodle about $350.00...rented the bearing tools from Autozone....took my time....Cutting the push rods was a sackshriveling leap of faith...LOL...It was more intimidating than it actually was...I am glad i did it though...
Jimmie
Jimmie, here is my map (assuming the upload feature works). Enjoy!
I run the 204's along with 1.725 rockers on my 96" FXDB - produced the same dyno numbers as if 103 Stage II. I'm happy, especially knowing puching it out to 103 will make it even better.
Hi, what numbers did you get on the dyno?
I'm probably going with the SE204s as well but trying to decide if the SE 1.725 rockers are really worth the extra time and money. I don't think anyone has ever done a real comparison of with and without so I guess I'll never know.
Hey Tim, Looks like you are running slipons for exhaust, did you change the intake or is it stock? Compared to stock how does your bike run with the new cams?
