Fat Bob Stage 1 Complete! (with Dyno Chart)
Couple of comments ... not sure why your tuner did it that way, however, most tuners use the same standard scale on both sides of the graph ... (in that situation, the torque and HP curves cross at 5,250 RPM) ...
Below is a snapshot from the Screamin Eagle catalog showing comparison of stock with the SE Stage I ... (A/C, SE Slip Ons, and Tune) ...
Looks like your setup with full exhaust is marginally better than the SE Stage I ...
Enjoy ...
R/
'Chop
Thanks Chop. That 2 scale graph threw me off too, when I first looked at it. I have seen some charts before though that didn't have the same scale on both sides. If you eyeball where each line is at 5250rpm, you will find that they are at about the same number, so they would intersect if the same lines were placed on a dyna sheet with the same scale on both sides.
Puffdaddy - thanks man. I know I'm giving up a little bit with the 2-2, but I think I got pretty good numbers and a nice smooth curve. I have definitely seen worse dyno sheets. The looks and sound was what made me finally decide to go with the Big Shots for my exhaust.
Thanks rooti! They seemed good to me, but I've seen so many dyno sheets with different set ups that I couldn't remember best/worst for my specific set up.
Thanks Sharkman! I am really happy with it. The audio on my video doesn't quite do it justice. And while I had thought I was done with mods for now, I am thinking about changing out the wheels and sprocket to the black - cut back (contrast cut). And my new Sick Saddle should be shipping soon also.
