Shock Springs
Old Feb 25, 2007 | 02:45 PM
ralfareno's Avatar
ralfareno
Default Shock Springs
Hello All! I have a problem bottoming out on my Dyna Lowrider. Does anyone know how to adjust the shock springs? I have a service manual and is states it can be done but it's not clear on how to do it. Thanks Ride On.
Old Feb 25, 2007 | 03:00 PM
clayman's Avatar
clayman
Default RE: Shock Springs
If you look at the bottom of the shock you will see some notches cut all the way arround, you need a shock adjusting tool to fit in there then you can adjust them. Or if you have a jack you can lift you rear tire off the ground and turn the shock by hand. This is how ive done mine.
Old Feb 25, 2007 | 03:50 PM
TOMMAY's Avatar
TOMMAY
You can also use one of those strap type tools to grip the lower part of the shock cover to adjust the shock.
If you're confused about the settings,just remember that the more shock exposed at the bottom the more preload or stiffness.
Good Luck
Tom
Old Feb 26, 2007 | 01:45 AM
veniculum's Avatar
veniculum
It's called a spanner wrench, and every dealer should carry them. I still had one from my old metric bikes....and that worked just as well. Usually, they cost around 10 bucks.
Or you could do it the old fashioned way...get a good grip on it and give it a twist.
Todd
Old Feb 26, 2007 | 05:52 PM
ralfareno's Avatar
ralfareno
Thanks for all the help guys. I turned the adjustment sleeve with brut force. I will take a test ride in a few days.
Old Feb 26, 2007 | 07:35 PM
ralfareno's Avatar
ralfareno
[align=center] [/align]
Old Mar 9, 2007 | 12:31 AM
ironbyron's Avatar
ironbyron
Springs are stiff, ride is too, start on the lowest setting. Miss the potholes when & if you can.
JAMESAK51
2014-2024 Touring Models
May 17, 2014 10:28 PM
Smither's
May 16, 2012 05:45 PM
mike56
Mar 6, 2010 05:27 PM
antman27
Aug 24, 2009 09:09 AM
LuvtheMud
Jun 23, 2007 05:38 PM
