Help bike shuts off
Old Jun 21, 2013 | 05:04 AM
peter deering's Avatar
peter deering
Default Help bike shuts off
I ride a 07 superglide. twice i was out for a run at approx 40 mph and my bike just died. Bike stilll has power but the fuel pump would not cut in unless i pulled the max fuse for approx 30 seconds and it reset. When started the engine lite will go out and then come back on for a few seconds and then go back out again. I run se slipons xied and v and h vo2 breather.
Old Jun 21, 2013 | 07:09 PM
Sumpnut's Avatar
Sumpnut
When it happens check the error codes..
Old Jun 22, 2013 | 07:28 AM
SC-Longhair's Avatar
SC-Longhair
I've read other posts similar to yours over the past few years and usually ends up being the fuel line inside the tank having a pinhole or crack. There is also a filter in there as well. Might be worth a look see.
Old Jun 22, 2013 | 07:36 AM
Notz's Avatar
Notz
i had the same issue mine was a 7 dollar relay changed it and boom all good
Old Jun 22, 2013 | 04:40 PM
peter deering
Tks guys will check both hoses and relay
Old Jun 22, 2013 | 04:57 PM
bdtaylor1979's Avatar
bdtaylor1979
Mine did that last week and I heard a high pitched whine/whistle ever since. I took it in to get checked out under the extended warranty and they told me it was the fuel pressure regulator. Still waiting on the regulator to come in and see if it takes care of it.
Old Jun 23, 2013 | 03:34 AM
Jbco2's Avatar
Jbco2
If its not in the fuel pump,
Their is a re-occurring problem with the tps-IAC calibration, 2007-2008. Common problem.
Keep us posted so we can help.
Check the fuel pump system first.
Joe
Old Jun 23, 2013 | 12:45 PM
peter deering
Tks agn guys, sounds like it could be the FPR. I to have been hearing the whine or whistle of late. My hearing isnt very good so I can barely hear it. Let me know how you make out there bdtaylor1979. I will do likewise.
Old Jun 26, 2013 | 07:29 AM
peter deering
Well talked with one of the mechs at the local dealership. He says to try one of the relays on the fuse panel. thunderstorms and heavy rain for next couple of days. Soon as it stops Ill get a test ride and post an update.
Old Jul 2, 2013 | 05:19 PM
peter deering
Well i changed both relays and got out for a run today got about 5 mi from the house and she shut off. Lost power, i pulled the maxi fuse and rekeyed and she started and no prob going home. Plugs look great looks like I will have to go inside the tank this weekend. Any advice appreciated Tks
