Transmission oil was low
I just changed oil, tranny oil, and primary chaincase oil. I checked tranny oil level before draining and it didn't register on the dipstick. The tranny oil is supposed to be .95L and I got .60L when I measured how much I drained. The bike has 5300 miles on it and I don't know the history although the previous owner (2nd) said the first owner did the 1000 mile service.
Any thoughts on low tranny fluid and anything I can do about it now?
Thanks in advance.
Thanks in advance.
Very little you can do NOW . If you don,t have any leaks and it gets low again you have a problem . That would be my only concern at this point .
I have learned if you your self did not do the service you have no idea how it was done .
The bike could have been low on oil all this time OR NOT ?
Im not certain and this has always been something I've wondered, I believe it's supposed to be on the stand but I'm not 100% certain. On my last fluid change I added oil with the bike level and not too long later my check oil light would flicker going up steep hills. Checked it on the stand and it showed super low.
Thanks in advance.
Thanks in advance.
Probably the person that did the last service did not put enough in. If it were leaking you would know it by the trailing oil film all over the bottom. Mine calls for these checks to be made with the bike on the jiffy stand. Trans dip stick resting on top of the threads and the motor oil dipstick screwed in. One of the reasons I use Bel-Ray fluids, they are tinted red so you can tell the difference between trans oil and engine oil. Jusayin.
