Raked bearing cups, anyone used this kit?
Old 11-25-2013, 10:00 AM
Guitarman_sg's Avatar
Guitarman_sg
Guitarman_sg is offline
Default Raked bearing cups, anyone used this kit?
I was thinking about adding another 3° of rake to my wideglide and found this site that sells raked bearing cups so essentially it is like chopping the frame instead of putting on raked trees. Has anyone used one of these kits? If so how do you like it?
http://vulcanworks.net/Fork-Cup-Set-...e-p-17035.html
Old 11-25-2013, 11:43 AM
97dyna's Avatar
97dyna
97dyna is offline
Default Vulcan kit
I installed the same kit on my FXDL. Vulcan is very good quality. I had raked triple trees on a previous Dyna and the raked neck cups are more stable at higher speeds. IMO
Old 11-25-2013, 12:20 PM
okbill's Avatar
okbill
okbill is offline
Might be a less expensive way to achieve a rake. Keep us informed and show some before and after photos if you go this route. I could be interested in this kit also.
Old 11-25-2013, 12:30 PM
! rock103 !'s Avatar
! rock103 !
! rock103 ! is offline
I would think the added rake would lower the front end a bit. Wondering if one would want longer forks to compensate??
Old 11-25-2013, 10:59 PM
97dyna's Avatar
97dyna
97dyna is offline
Default shocks with raked cups
It will lower the front end some. (You can use a rake and trail calclator.). I wanted lower, so I went with shorter shocks as well (long after the install - which was very straight forward.) Longer fork tubes will stretch out the front for that look. Regardless, less adverse effects. Again - IMO from this mod.
Old 11-25-2013, 11:16 PM
FXD_noob's Avatar
FXD_noob
FXD_noob is offline
Subscribed! I'm also interested in adding rake to my '05 Super Glide, I had no idea they sold raked cups...first time I hear about this product!
Old 11-27-2013, 07:50 AM
Guitarman_sg
I trigged it out, and it will lower the front 1 1/2" the same as I lowered my rear, so I will keep my stock tubes and everything will be level. I will make sure to post pics of the install, and before and after pics. May be a while before I can get to it with the holidays.
Old 12-02-2013, 05:51 PM
FXD_noob's Avatar
FXD_noob
FXD_noob is offline
Ok, keep us posted then!
Old 12-02-2013, 06:57 PM
ynots's Avatar
ynots
ynots is offline
Wow, I never would have imagined +3 deg would make such a difference
Old 12-18-2013, 10:45 PM
FXD_noob's Avatar
FXD_noob
FXD_noob is offline
So...any progress on this?
2NAHNTR
02-21-2009 04:07 PM
Leedy
08-30-2007 02:49 PM
traveler
02-26-2007 02:30 PM
RAJ
01-04-2006 01:32 PM
Boogie Knights
11-04-2005 12:51 PM
Quick Reply: Raked bearing cups, anyone used this kit?
