Rake Increase
~Joe
Case in point; I have an 04 Lowrider stock with 32º neck and 0º trees 5.1" trail. They used the same frame with the Wideglide but added 3º trees and 2" longer front end to reduce the trail to 3.7"
I added 3º raked cups for a total frame rake of 35º and a wide glide front end with 3º raked trees for a total rake of 38º. From my personal experience I have had this bike up to 115mph with windshield on and it is as soilid as a rock.
There are several factors determining trail. ie. neck rake, tree rake, length of front end, tire size, and even the heigth of the rear (dropping the rear, or raising the front increases the total angle of the frame.)
Before changing the geometry of any motorcycle it has been suggested that research be conducted. I concur. The following link has excellent calculators to help you play with the numbers before you invest those bucks.
http://www.rbracing-rsr.com/advchoppercalc.html
[IMG]local://upfiles/6102/918C11CB718441E5A86B386620B421A7.gif[/IMG]
For some reason I can't download the pix to you files are too big.
