Rake Increase
Old Aug 26, 2007 | 08:51 PM
harleyvato1963's Avatar
harleyvato1963
Default RE: Rake Increase
What did you do for the treestem, doesn't need to be longer?
Old Aug 28, 2007 | 12:30 PM
ameristo's Avatar
ameristo
I started with stock 32º frame and 0º trees. I then added 3º cups and a FXST front end which comes stock with 3º rake in the trees. For an after picture just look above at my last post. Yes the neck post is longer by about 1". I purchased the kit from 2orangeharleys on ebay, it came complete with bearings, bearing races, cups, lower dust cover, snap ring and longer neck post. They come with pretty good instructions. However, I would suggest that you put the post in the freezer for a couple days, warm up the lower tree and press out the old post. Grab the one out of the freezer ond press it back in. Oh, did I say 10Ton press?
Old Aug 28, 2007 | 12:41 PM
harleyvato1963
Where did you find a FXST fornt end with a 3 degree rake, all I've seen and read say 32 on the neck and 2 in the tree.
Old Aug 28, 2007 | 05:59 PM
ameristo's Avatar
ameristo
You may be right..... I bought a 2000 fxst front end from ebay and the seller told me it was 3º, same as the dyna wide glide. There is a noticable rake but I did not measure it, so, you may be right.
Old Aug 28, 2007 | 06:04 PM
traveler's Avatar
traveler
ORIGINAL: ameristo
Traveler, with all due respect, I think you mean raked cups will increase trail and raked trees will decrease trail.
Case in point; I have an 04 Lowrider stock with 32º neck and 0º trees 5.1" trail. They used the same frame with the Wideglide but added 3º trees and 2" longer front end to reduce the trail to 3.7"
I added 3º raked cups for a total frame rake of 35º and a wide glide front end with 3º raked trees for a total rake of 38º. From my personal experience I have had this bike up to 115mph with windshield on and it is as soilid as a rock.
There are several factors determining trail. ie. neck rake, tree rake, length of front end, tire size, and even the heigth of the rear (dropping the rear, or raising the front increases the total angle of the frame.)
Before changing the geometry of any motorcycle it has been suggested that research be conducted. I concur. The following link has excellent calculators to help you play with the numbers before you invest those bucks.
http://www.rbracing-rsr.com/advchoppercalc.html
[IMG]local://upfiles/6102/918C11CB718441E5A86B386620B421A7.gif[/IMG]
I guess what I ws trying to say, is that to keep the overall trail decent, you have to do both the cups and the trees. I did the computations, and if you do just one...either one...the trail is too small, making it VERY dangerous at speeds over 45 MPH!
By using both, I will still have 3.5 inches of trail....which is shorter than stock, but still has enough trail, to where it won't end up killing you! Keep in mind that a Superglide has a 28 degree neck versus the 32 for a Lowrider, so the "computations" will be completely different.
~Joe
Old Aug 28, 2007 | 06:09 PM
traveler's Avatar
traveler
You can buy forks with 3 degree raked trees on eBay any day of the week....very common. I bought my Rick Doss forks for under 500 bucks...and they retail for $750 + !!!
Old Aug 28, 2007 | 06:16 PM
ameristo's Avatar
ameristo
Hey Traveler, let me know how that front end does for you. I have the stock HD 41mm WG on mine and a 1.5" tank lift. I'm afraid if I went any higher it would hit the tank. Also I wanted custom front trees but 1. I was not sure if you would have to have a longer neck stem machined or if they furnish it. 2. The stock trees are cut out and they fit mighty close to the tank as it is. I was not sure about the clerance between the tank and trees.
Old Aug 28, 2007 | 06:25 PM
rustyred's Avatar
rustyred
seegar cycles.com they also sell complete chopper kits,,,,
Old Aug 28, 2007 | 06:27 PM
rustyred's Avatar
rustyred
seegercycles.com
Old Aug 28, 2007 | 08:32 PM
traveler's Avatar
traveler
The Seeger Cycles kit is a 13 degree kit, that uses the 39mm fork tubes, and the trees are aluminum. The AME kit has a 41mm fork tube option, is available in 9 degree, 14 degree, and 18 degree variants. Also of note, is the AME trees are chromed steel.
~Joe
