Switchback tail light help
Old 01-19-2014, 10:59 AM
Bobby12012's Avatar
Bobby12012
Bobby12012 is offline
Default Switchback tail light help
I am in the process of putting a switchback fender on my 2013 superglide custom ... Picked up all the parts from dealer yesterday and zero parts have any instructions .... There is a little led light for license plate and a two pin clip that it plugs into .... And then to where in the circuit board?
If anyone has the switchback setup and can take a picture of where everything plugs in it would be greatly appreciated
Thanks
Old 01-19-2014, 02:38 PM
Chinashop bull's Avatar
Chinashop bull
Chinashop bull is offline
All roads lead to Rome. Or in this case, the tail light.
Old 01-19-2014, 09:20 PM
Bobby12012's Avatar
Bobby12012
I appreciate the reply and the picture , I have this picture but it does not show where in the circuit board the license plate light plugs in
Old 01-19-2014, 10:11 PM
Chinashop bull
Everything plugs into 31 inside the tail light. Connector 46/51 plugs under the seat. There's only 1 matching connector.
Old 01-24-2014, 03:04 PM
Bobby12012's Avatar
Bobby12012
It helps to find out that the dealer gave me the wrong plug ��
Old 01-31-2015, 03:18 PM
Rainydave's Avatar
Rainydave
Rainydave is offline
Stage I
Thanks
Just done the same mod to my street bob. The plug goes through the fender then out again through the circuit board and plugs in next to the indicator. You should have both indicators, the brake light and the plate light in there. If you've bolted the indicator bar on already, youve probably got the plug outside and dont know where to put it. I know because I did the same and had to take the light bar off again! Good luck!
Philly1200
04-19-2016 08:31 PM
Bobby12012
01-19-2014 12:42 PM
Sancheese
05-04-2013 12:15 PM
lorenski
09-12-2012 08:45 AM
SnakeEyes
10-21-2008 10:33 PM
Quick Reply: Switchback tail light help
