Horn Relocation - Wiring
Old Feb 20, 2014 | 12:24 AM
rockon's Avatar
rockon
Default Horn Relocation - Wiring
So I've got a DK Custom sportster horn that I want to relocate under the battery box.
Problem is I snipped the horn wires when I removed the stock horn years ago. I was hoping I could run back along the wires and find the connectors to hook up the harness that DK included, but it looks like that was on the business end that I snipped off. O.o
What's the simple answer here? I'd rather not solder...I hate electrical mods to begin with but I won't make inspection here in TX without it.
Old Feb 20, 2014 | 12:48 AM
ShiftyCapone's Avatar
ShiftyCapone
You could always buy a new Multilock connector off of eBay or the likes. Maybe DK can shed some light on the connector needed if you don't know...
Old Feb 20, 2014 | 01:14 AM
rockon's Avatar
rockon
Well, problem is I snipped it, and there doesn't appear to be another connector in the line after that (from what I could tell looking at the wiring diagram in the service manual)...the two horn wires go back to the same wiring harness connection as a bunch of other electronics and that's it.
Old Feb 20, 2014 | 01:17 AM
ShiftyCapone
Should be a connector on the new horn no? That's what I was talking about. If nothing else, the horn should at least spade terminals. Extend the wires and crimp on the connectors. Pics would help us help you..
Old Feb 20, 2014 | 04:32 AM
loopie's Avatar
loopie
pretty easy fix really,, out off a 10 scale .. with 10 being a mechanics job, its a 1 on the scale... if you cant figure how then best take it some one, other wise you will do more damage.
Old Feb 20, 2014 | 07:15 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
[QUOTE=loopie;12345705]pretty easy fix really,, out off a 10 scale .. with 10 being a mechanics job, its a 1 on the scale... if you cant figure how then best take it some one, other wise you will do more damage.[/QUOTE I agree.
Old Feb 20, 2014 | 08:26 AM
groundpounder51's Avatar
groundpounder51
Welcome from Northeast PA.
Old Feb 21, 2014 | 12:00 AM
rockon's Avatar
rockon
Yes, the horn has spade terminals. I was hoping that when I ran the wires all the way back I might find a similar connector that I just didn't see when I snipped them years ago, but nope.
Here's a few pics.
Attached Thumbnails Horn Relocation - Wiring-image.jpg   Horn Relocation - Wiring-image-1-.jpg   Horn Relocation - Wiring-image-2-.jpg
Old Feb 21, 2014 | 12:10 AM
B_nichols's Avatar
B_nichols
If you are worried about soldering because its more permanent, use male/ female flat connectors. Or go to any auto parts store and get some universal connectors and put it in.
Old Feb 21, 2014 | 02:49 AM
loopie's Avatar
loopie
Here's a few pics.
1 minute work too instal 2 new male spade terminals ,,,, whats the issue,,, and really we are talking about some one who removed the only warning device on their bike, why didn't you just use tape and hide the wires and not cut the ends off, once again its above your ****in skill level
