S&S 106 Build Finally Done!!! Pic, Video, & Info!!!
UPDATES:
page 7 has first time ride impressions of the Hayden Tensioner
page 9 has Dyno resluts (113hp/120tq) & video outside
Finally fired her up today! Sounds and runs amazing. Havent gotten a chance to take her out due to the ChiTown weather, but can't wait for a ridable day.
Here is my parts/mod list w/ some prices:
$43.20 - Baisley plunger and LMR2 spring
$240 - S&S high performance premium lifter
$146.21 - S&S adjustable push rods with tubes
$620 - S&S 106" kit
$608 - S&S 585G Gear Drive Cam Kit
$250 - 2010 96" stock heads
$1,200 - Vee Twin Performance Stage 3 Heads
$226 - Chrome rocker covers and S&S roller rockers(found this used rockin combo via eBay!)
$40 - Screamin eagle clutch spring
$60 - Brake pedal mid control(sold part of my mids when I first got the bike, so i didnt need to but everything)
$30 - Rocker Cover Chrome Screw Kit
$55 - Chrome Tappet Covers & Screws
$91 - Cometic .030" Gasket Kit (Ended up getting S&S head gasket)
$60 - Mid Control Gasket Kit
$8 - Trans/case gasket
$89 - New Front Isolator(motor mount)
$1,300 - Darkorse(bottom end/crank work)
$400 - Screamin Eagle Compensator
$105 - Hayden M6 Tensioner
$18 - NGK Iradium Spark Plugs
$20 - Screamin Eagle Plug Wires
$120 - Case of S&S Oil & 5 S&S Oil Filters
Beginning to end was a long and expensive road.
Tear down. My run-out sucked and had few grooves on shaft and oil pump so off to darkhorse to fix both and beef up the lower end:
Heads bought off 2010 Softail sent to Kirby at VeeTwin Performance. Springs installed are 175lbs.
Bottom end back from John at Darkhorse. True/Balance/Blue Printed, Timkin, Welded Crank:
New perforated baffle for D&D Fat Cat:
585 Gear Drive:
$620 - S&S 106" kit
585 Gear Drive:
Maybe my stuff was faster from DH cause I drove there and said I was picking it up. All good things come to those that wait...........
Can't wait to break her in and put her on the dyno. Hoping for at least 110HP and I will be very happy.
Your gonna love it.
The only difference in mine vs yous is I went with easy start SS585 cams.
Pulls fair to 3,000 then at 3,000 hang on for a great feeling.
You should get close to what your expecting.
Be care when 2 up and hitting it in first at 3 grad the front end is gonna come up.
forgot, when it gets to operating temps. the lope will be great.
