Rear turn signal help
Old 03-17-2014, 10:34 PM
Dyna_Bagger85's Avatar
Dyna_Bagger85
Dyna_Bagger85 is offline
Default Rear turn signal help
I had to get dual filament housings on the rear of my 2008 Street Bob, they came in today and they are 3 wire. My stock ones were 2 wire and I can't figure out how to wire them up so that I can still use my RUN/TURN/BRAKE module.
I have the LED inserts and hooked up the ground and the one that was the brightest (turn signal) but when I hit the brake nothing happened but the turn signal blinked normal then fast light there was a light out. I'm not electrical smart so I have no idea what to do...HELP!!!!
Old 03-17-2014, 10:36 PM
Bagged Sbob's Avatar
Bagged Sbob
Bagged Sbob is offline
Are your stock lights run/turn/brake?
Old 03-17-2014, 10:39 PM
Dyna_Bagger85
No, I just got the run turn brake module. I had an issue with my air ride when I went to low and it ripped the casing off of the wires. Got to thinking if I may have fried my module.
Old 03-17-2014, 10:46 PM
Bagged Sbob
Very possible, if you are using led. Don't need the module. You could use a diode and a 1.4k resistor.
Old 03-17-2014, 10:47 PM
Dyna_Bagger85
I moved a while back and when packing my stock rear turn signals got misplaced. I had been running the license plate with them integrated. Can anyone tell me if the stock turn signals are dual or single filament? Parts manual is showing single, I just want to be absolutely sure!
Old 03-17-2014, 10:56 PM
Bagged Sbob
From what I see, if you have the big tail light or the donkey dick tail light. Your turns signals are single filament. But you could always pull a single wire off your tail light to run the stop light on the led one.
Old 03-17-2014, 11:07 PM
Dyna_Bagger85
Don't have either stock tail lights and don't plan on using them. I had the kuryakyn RUN/TURN/BRAKE license plate. I want to go back to stock style turn signals. Couldn't I just wire up the LED inserts straight to the plug's and do away with the socket housing?
Old 03-17-2014, 11:21 PM
Bagged Sbob
Yes you could but you won't get all the functions
Old 03-18-2014, 06:04 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Rear turn signals are single filament.
You cannot use the dual filament housings in combination with the R/T/B module.
Go here to find 2008 Dyna models wiring diagrams.
If you want to use the dual filament housings you have to connect the blue wire to pin 1 on the tail light board and the 5W filament will light up like the day marker on the front.
Pin 1 = tail light
Pin 2 = brake light
Pin 3 = ground
Amp Socket Wiring Housing 3-Position p/n 73153-96BK
Receptacle Contact p/n 73191-96
Old 03-18-2014, 10:19 PM
Dyna_Bagger85
I ended up just buying the single filament LED's and a new RUN/TURN/BRAKE module since mine is fried. So now I have red dual filament LED's and black nickel housing with dual filament sockets up for sale.
Bandito
Electrical/Lighting/Alarm
05-18-2018 06:23 PM
ClayM
01-10-2015 01:38 PM
ClayM
01-06-2015 01:30 AM
Dyna_Bagger85
03-18-2014 05:16 PM
sportyguy69
04-29-2013 05:02 PM
Quick Reply: Rear turn signal help
