07 street bob torque specs HELP
Old Apr 19, 2014 | 06:59 PM
vatoloco5's Avatar
vatoloco5
Default 07 street bob torque specs HELP
Im changing the front and rear tires on the bike and cant find my manual in all the clutter. If someone can help me out with the torque specs to get back on the road it would greatly be appreciated... thanks
Old Apr 19, 2014 | 09:17 PM
nevil's Avatar
nevil
Can't get to my shop manual, but these are for an 08, should be the same. Or at least close enough unless someone posts them for an 07.
https://app.box.com/s/055f41ac2338cbab4cff
Peter Black's Avatar
Peter Black
From the 2007 dyna service manual front axle nut 50-55 ft-lbs
Rear axel nut 92-98 ft-lbs
I happened to have my book open to the torque values page how lucky are you!
Old Apr 20, 2014 | 01:40 AM
vatoloco5's Avatar
vatoloco5
Thanks a lot guys. Could you also help me out with the bolts for the rear sprocket, rear brake disc and the front brake disc... The pdf nevil attached has everything but didnt know if it changed from the 07 to the 08
Old Apr 20, 2014 | 10:00 PM
Peter Black
Front brake disk screws 16-24 ft-lbs
Rear brake disk screws 30-45 ft-lbs
Blue loctite
Belt sprocket 55-65 ft-lbs
Red loctite
Do not reuse these bolts! Get new ones!
Old Apr 21, 2014 | 04:55 PM
vatoloco5's Avatar
vatoloco5
Blue loctite
Red loctite
Thanks again... so do i get all new bolts or just the belt sprocket ones with red loctite?
Old Apr 21, 2014 | 06:23 PM
Peter Black
Get all new bolts these are single use, if you need part numbers i can look them up tonight when i get home.
Old Apr 21, 2014 | 08:37 PM
vatoloco5's Avatar
vatoloco5
Ok i understand... and yes part numbers would be appreciated, unless i can just go up to my local HD shop and tell them the bolts I need??
YammyBase
Apr 20, 2021 03:41 PM
fatbob_jay
May 9, 2019 08:58 PM
brihvac
May 16, 2011 07:10 PM
mobsters1972
Jun 29, 2010 07:57 PM
Zinje
Aug 31, 2009 10:04 PM
