Ultima Wiring for Big Twin 18-346
Old 08-14-2015, 03:55 PM
Kenkenokio's Avatar
Kenkenokio
Kenkenokio is offline
Stage III
Exclamation Ultima Wiring for Big Twin 18-346
I installed the Ultima Wiring for Big Twin to my perfectly running Ultima 127 with an Ultima Programmable ignition already running in it. I wired it up and I cannot get power from the coil wire out of the box. I don't have blinkers, don't have neutral switch (ultima 6 speed) and don't have oil pressure switch. The ignition switch (key) powers up fine, it turns over fine (starter relay good) but the Ultima Wiring Box won't sent power down the coil power wire (white with black stripe). I attached a sloppy picture of what wires I used. Is there something I'm missing? Do I need the oil pressure switch? Do I need a neutral switch? I have gone over it ten times with and ohm meter and their are no shorts. All new wires. I think the Ultima Wiring Box is crap and I'm going to have to bypass the coil wire. Thoughts?
Attached Thumbnails Ultima Wiring for Big Twin 18-346-img_20150813_195426.jpg   Ultima Wiring for Big Twin 18-346-img_20150813_194603.jpg
akmorris81
EVO
21
06-06-2020 09:20 AM
MJR35
08-04-2018 04:30 PM
707airbrush
Ironhead
05-03-2018 10:36 PM
Blk80bike
Electrical/Lighting/Alarm
09-25-2016 08:09 AM
rgm
Custom Models
12-10-2007 09:12 AM
Quick Reply: Ultima Wiring for Big Twin 18-346
