ECM Connection lost, help please
Old 01-07-2018, 09:12 AM
Vilrandir's Avatar
Vilrandir
Vilrandir is offline
Stage IV
Default ECM Connection lost, help please
Hello all! I've been having some trouble with my 2015 Heritage Softail Classic it will ride with no problems at all and suddenly lose all power, engine shuts down. I'll pull up and start it again without issue but this happens again sometime afterwards. I have an FP3 on it which gives me the following error codes :
U0100 ECM lost comm
B2262 front brake switch stuck
B2201 ignition switch oo with VSS
P1632 odometer learned up
​I think the front brake error is a separate one, on the ride back home (after noting the brake error) when the red light came on I would use the front brake abruptly which unstuck the switch and turned the light off (bike didn't shut down), so I'll check what's getting it stuck and properly fix that separately. However, the bike shutdown will happen without getting a red light indicator, so I think the error codes are not related.
Could you guys share some insights on how to look for an answer on what's causing the ECM comm lost?
Old 01-07-2018, 01:04 PM
nevil's Avatar
nevil
nevil is offline
I don't have enough in depth knowledge of a lost comm, but would start with the simple things. Check battery cables at the battery and ground connections. Pull the ECM plug and look for bent pins. Maybe it's not securely seated. Clean the pins with electrical contact cleaner and reinstall.
Old 01-07-2018, 09:06 PM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,308 Likes on 1,907 Posts
I don't have any Softail manuals, just touring. Touring doesn't show a P1632 that I could find but a search came up with this:
https://www.hdforums.com.au/Thread/608899/1
U0100 has a priority of 3 so it would be the first on my list to check. Causes can be Open in the CAN Buss High or Low to the ECM, Open in the System Power to ECM or Open in the ECM Ground.
Schematics can be found here:
https://serviceinfo.harley-davidson....320433&id=5542
Old 01-08-2018, 07:50 AM
Vilrandir's Avatar
Vilrandir
Stage IV
Thank you guys I'll take a look after I come back from work today
Old 01-08-2018, 09:18 AM
bustert's Avatar
bustert
bustert is offline
most comm issues are in the wiring specifically the weakest link the connectors. if comm is lost, the ecu can not receive nor transmit data so it shuts down so the run/die and repeat. you could use a data trace probe but when it is intermittent it becomes a tough dog.
Old 01-13-2018, 04:53 PM
j_bee's Avatar
j_bee
j_bee is offline
A U0100 can sometimes appear for a few reasons that might not be causing your issue.
To verify it is a likely candidate you should delete the codes and see what ones come back when the issue next shows itself.
If the lost communication error comes back then it is the item to focus on.
Does the FP3 have the ability to show you when the fault occurred. As in how many trips ago and how many times it has happened? Or maybe it has the option to show you if other modules set the code against the ECM.
It might have the ability to do live data logging
When it shuts down, do you lose all vehicle power...speedo drops to zero, lights go out, odometer goes blank, etc...or does the engine itself turn off only?
Does it happen completely randomly or fairly consistently?
Have you had any changes to the handle bars or work done that coincided with the problem arising?
Definitely do the checks suggested by Nevil, make sure the basics are covered, particularly the grounds located on the frame in front of the battery.
imbuhlman
12-27-2018 10:02 AM
Philokc
07-30-2018 10:36 AM
Afishinado
Electrical/Lighting/Alarm
05-16-2016 01:59 PM
Teardrop
07-30-2011 09:11 PM
kyBriar
02-03-2010 09:19 PM
Quick Reply: ECM Connection lost, help please
