I thought I knew how to use a volt meter
My 2002 FLHTCU is not charging at the moment. I followed the charging system diagnostics, and have ordered an new regulator.
I have several meters, all are 15+ years old. All different brands. None will show the ac voltage from the alternator. Testing a wall socket show 120vac on all three voltmeters.
What the heck and I doing incorrectly? I connect the volt meter to the alternator, both pin, and it shows 9-24 volts. 24 volts at about 3600 RPM. I thought it should show 24vac per 1000 RPM. I am not seeing the expected 80-100vac.
That`s because the alternator has a built in circuit that changes A/C volts to D/C volts as well as dropping the voltage to a usable level to charge your battery. You can`t read the generated A/C voltage, only the output D/C voltage. You can read an A/C voltage drop to ground from the positive battery terminal, which will read very low (something like .3 volts) to indicate if your alternator is functioning properly. But this has nothing to do directly with the final D/C voltage output. In other words, there is nothing wrong with your meter.
Check each of the 3 wires from the stator separately between the wire and ground. Each of the three wires should have an AC voltage dependent upon RPM between about 10 and 30 volts AC. I don't recall exactly. Out of the regulator should be a pretty steady approximately 14 volts DC. These are with the engine running.
