2015 ultra classic tour pak removal issue
When I remove the tour pak from the 2015 ultra classic, my tail light and brake light both go out...thought it was the lamp/bulb, that checked good. I bought a new LED tail light/brake assembly, it did not work either. I have the additional saddle bag lights, so I could still ride it, since I would have tail/brake/turn lights, but I would like to find out why the tail light assembly goes dark when I unplug the tour pak. Any advice or ideas would be appreciated before I try to tackle a wiring harness/grounding issue within the tour pak (which is where I suspect the problem will be found) and add an additional return for the signals to the brake/tail light fixture. Thanks!
The tour pak has a connector beneath the seat so it can be removed, and that removal causes the lack of tail/brake light but does not cause the additional bag lights to stop working. I guess I got lucky to add them before removing the tour pak, as I had no tail light and no brake light with the tour pak removed. At least I have some lights on the rear, but didn't want to sacrifice one to add two......
