Brake Light Flasher
Old Apr 10, 2008 | 03:43 PM
HarleyArcher's Avatar
HarleyArcher
Default Brake Light Flasher
Does anyone know if you add one of the brake light flashers like the "back off" unit will it make only my stock brake light flash or will it also make my TP spoiler brake light flash? I really want the TP spoiler light to flash since it is at eye level of most cages. Thought about just getting one and putting it in line with the TP wireing but if I can get both to flash that is just added safety in my opinion. Any help would be appreciated. Thanks Bryan
Old Apr 10, 2008 | 04:19 PM
ballpeen's Avatar
ballpeen
Default RE: Brake Light Flasher
Heres a site for you to check out, I have a classic and I choose to only have the tour pack lights flash, the options are up to you. This should help. Tim
http://www.kisantech.com/
[IMG]local://upfiles/46392/B72746F802C846AA8ACD0CCE1D9C6B36.jpg[/IMG]
Old Apr 10, 2008 | 05:13 PM
rsofa's Avatar
rsofa
ORIGINAL: HarleyArcher
I just wired my BackOff XP to the tour pak lights last week it can run both brake and tour pak just depends where
inline you hook it up I installed mine inside the tour pak it took about 30 minutes to do!!
Old Apr 10, 2008 | 05:46 PM
HarleyArcher
ORIGINAL: rsofa
I just have a standar TP with the TP spoiler, so the only light I have on my TP is the LED run/brake light. I figured I could just wire the BackOff into that wireing, but was wondering if there was anywhere further down in the wireing harness I could splice it in to make all the brake lights flash. Any ideas there? Thanks Bryan
Old Apr 10, 2008 | 06:12 PM
Windup08's Avatar
Windup08
If you wire in under the seat all the brake lights will flash. I've had the BackOff module on all my bikes, on my Dyna the version I had would flash the brake light and do a wig-wag flashing on the rear turn signals (each would alternate flashing 4 times then go on solid). If Signal light is on then only the one brake light would flash.
I haven't put one on my Ultra yet as I'm still looking to decide which one I want, and some have warnings that they could make the cruise control not work.
Old Apr 10, 2008 | 06:37 PM
rsofa's Avatar
rsofa
ORIGINAL: Windup08
I heard that too but they say the XP module will work fine I haven't tried it yet with cruise though!
Old Feb 12, 2013 | 07:33 AM
Bullitt59's Avatar
Bullitt59
I have a 2011 Ultra Classic and am about to install the Backoff modulator. Mine has 2 wires, one red, one white. Anyone know where the brake light wires are under the seat?
kxbm4h
Electrical/Lighting/Alarm
Aug 23, 2018 07:57 PM
EasTexUltra12
Oct 16, 2012 11:34 AM
UltraEd
Dec 17, 2008 08:32 PM
sldavis
Mar 31, 2008 08:57 AM
greg09997
Feb 27, 2008 10:15 PM
