RRi SigZ V2
RRi SigZ V2
RRi SigZ V2, bought a set of these, they’re front running light that are supposed to turn amber when you turn on the blinker.
I got them to replace the Custom Dynamics lights. That worked flawlessly by the way, I just wanted a full cluster on the running light.
My problem is that the new light is supposed to turn off the white running light and the amber light is supposed to take over. But the white is not turning off and is washing out the amber. They bench test fine just won’t work on the bike.
Any suggestions?
Any suggestions?
Well it seems that the load equalizer that’s built into the run/brake/turn module is reducing the voltage and not allowing the switch inside the light to turn off the white running light and turn on the amber.
That sucks, it’s a great concept but not worth me adding extra relays to isolate them from the module.
Anyone following this post the Badlands Run/brake/turn module lists an option to connect the power wire to the Blue running light feed instead of connecting it to a positive from the ignition. This connection creates a backfeed that stops the SigZ lights from working correctly.
The Orange/Yellow must be connected to the ignition.
Hope this helps someone else.
mshred
Electrical/Lighting/Alarm
01-28-2018 07:36 AM
koresample
02-09-2015 10:38 PM
