Dead as a door Nail
Dead as a door Nail
2011 FLHTCU, yesterday went for a ride with my son. I had no issues, pulled into the garage and called it a night. This morning I turn the ignition key, nothing, not even a single light, hum, nodda. I checked the switch it was set to run. I check the battery 13 volts, I check the main fuse, it tests good. The battery is 9 years old, I keep it on a battery tender, I figured it could be bad, but couldn't load test it. I purchased a new battery from batteries plus, it shows a little over 13 volts. I hook it up nothing. All the fuses check good, battery is good. I pulled the radio memory fuse and it has some voltage with the main fuse pulled. I've checked connections and they are tight. Could it be a bad ignition switch or run switch? I'm at a loss. Bike does not have the security system.
Has anyone had HOG road America pick up their bike from the house? I have the Ultra level service.
Thanks,
Matt
Thanks,
Matt
Mr.Softy
11
05-22-2015 12:58 PM
HKSkully
05-06-2013 10:18 AM
