I wired up my Performance Machine starter button and hooked it to the switch where there is power on the first click (no lights) and I get nothing. On the second click (lights on) it turns over. Ideas?
I believe I figured out what is going on after some thought. Number 30 on the starter relay is not hot on the first click, it is hot on the second click. Relay works on control side with switch in either position but load side only works on second position.
There are probably half a dozen ways to wire up the ignition switch.
If you want the headlight to not be powered on one of the positions but still have ignition (old style setup), it is easy enough to do.
That's what I am trying to do but lost as just how to do it. My thoughts are to change the wire that runs from #30 on the relay to the current position on the switch(lights on) to the position on the switch that the lights are off.
