Just found the loose ground wire for horn. Anyone know the location its supposed to go to? 2002 Road king. My guess under the tank as I just had it off to do a tank re-lining.
It reads like I missed a sentence or something.
Horn would use a positive and negative.
Positive is controlled by horn switch.
Ground/negative is frame.
Are you able to use frame side of horn bracket support bolt for Ground/negative in order to avoid tank removal?
I assume the positive connection comes off the horn button and is a male/female terminal plug. This is the ground to frame terminal??? Where does it go? I assume under the tank?
