Rivet size on headlamp... (06 Dyna)
Old 10-21-2011, 12:55 PM
thork86's Avatar
thork86
thork86 is offline
Default Rivet size on headlamp... (06 Dyna)
The headlight on my 06 Dyna has been shaking like crazy since June/July. Wasn't too bad at first, but is now a strobe-light at night and makes an annoying noise all the time.
Going to drill out the rivets and replace with bolts. What size are the rivets? And what size bolts did you use to replace the rivets?
Thanks very much.
Old 05-18-2019, 08:00 PM
Ironstang's Avatar
Ironstang
Ironstang is offline
Default Update
I know this is a prehistoric thread, but wanted to update it with info in case someone else needs the info like I did and couldn’t find it. I just drilled my rivets out and they measured .180. I used 10-24 button Allen head screws to secure it with the nylon lock nuts. Worked perfect.
beanoboy
03-13-2019 11:25 PM
CRF
05-05-2012 01:31 PM
kemery
Oil Archive (no new posts)
02-22-2010 07:47 PM
titus3:5
01-13-2008 11:31 AM
Motosurf
04-27-2007 04:06 AM
Quick Reply: Rivet size on headlamp... (06 Dyna)
