J&M Speakers on FLHX
Hey Guys,
A question for those who have installed the J&M 7.25" with the size down cone. I installed these on a 2006 FLHX and once I tried to put the outer fairing back on the speakers were hitting the foam that your suppose to install on the outer fairing. Anyone else having this problem? If so, what fix will work? Thanks!
is it the std or the rokker series?
if std check that you've got the adapters installed correctly.
if rokkers, make sure you're crossovers are facing inward toward the radio for each on.
