Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Top end gasket kit replacement 2009 flhx how much ??
my rear cylinder base o ring is leaking ,bought a top end kit ,how much do you think it will cost labor to replace all gaskets, on top end from cylinder up(cylinder,head,rockerbox ) or how many hours ??
