Excessive heat - is there a solution?
Old 04-08-2015, 09:07 PM
hdfarmboy's Avatar
hdfarmboy
hdfarmboy is offline
1st Gear
Ok thanks will check out his website. I may also put my bike back on a dyno to see where it is at.
  #32
Old 04-09-2015, 01:36 PM
djl's Avatar
djl
djl is offline
Received 2,048 Likes on 1,509 Posts
Fans work. Jason's fans are the most cost effective fan system I have seen.
  #33
Old 04-10-2015, 06:20 AM
hdfarmboy's Avatar
hdfarmboy
1st Gear
I am sure that fans can definitely make a difference. Just wish I had a side by side comparison to help make a decision. I really like the idea of a thermostat controlled fan so that it will continue to run to help cool the motor down after it is turned off.
Robtarra39
08-13-2013 08:42 AM
Mr E
Exhaust System Topics
01-22-2013 07:28 AM
yoosernayme
03-31-2012 03:12 AM
HDF Tech
Engine Mechanical Topics
06-24-2011 01:25 PM
GPHDXLC
09-24-2010 06:10 PM
Quick Reply: Excessive heat - is there a solution?
