06 88" tc tensioner question
Of course you can install the upgrade kit (PN 25282-11) per the previous post, posted by a pro BTW. However, there are some with limited funds that have gone another route by replacing the OEM tensioner shoes with the CYCO tensioner shoes and retaining the OEM cam plate which actually is quite adequate for the application. There are several "bolt in" cam options like Andrews 26, SE203/204 and more; I happen to like the S&S 509 for a bolt in application in a TC88.
You will need to replace the outer cam bearings if you retain the OEM cam plate and I would suggest upgrading the inner cam bearings to the Torrington B148s.
There is also an oil pump upgrade for the early OEM cam plate from Drag Specialties.
Been both ways & they each work well. Here's a link for the Cyco shoes. You'll see it comes with an installation tool, hang on to it for future shoe changes.
http://www.ebay.com/itm/191291272210...%3AMEBIDX%3AIT
You'll get more longevity out of the SE hydraulic shoes & the pumps a great addition (either way). All about wallet weight loss. The Crane 310-2's are another bolt in cams option.
Been both ways & they each work well. Here's a link for the Cyco shoes. You'll see it comes with an installation tool, hang on to it for future shoe changes. You'll get more longevity out of the SE hydraulic shoes & the pumps a great addition (either way). All about wallet weight loss. The Crane 310-2's are another bolt in cams option.
