Engine pinging
Old 05-11-2015, 09:45 PM
frankm205's Avatar
frankm205
frankm205 is offline
6th Gear
Default Engine pinging
Just had a 95 in re build with SE 10.5 pistons, 204 cams, tts tuner and fat cats done. Have about 200 miles on the new engine and having some pinging when I accelerate from 4th or 5th gear under load . its pretty slight and only happens when I crack the throttle. My mechanic says to run the bike for about 500 miles then he will dyno tune it. Question, is the pinging normal? I'm using 93 octane Shell gas.
Thanks
Old 05-11-2015, 11:36 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,820 Likes on 1,070 Posts
Do what the Mechanic is telling you to do and then pose your question after the Dyno tune if it's still pinging.
Old 05-12-2015, 06:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
With the intake closing number of that 204 cam, we sign off at 10.0 cr, as that is hovering at/near 200 psi ccp.
That is our threshold here.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 05-12-2015, 06:24 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
I agree with scott,if your mechanic was the builder,he should have known this.go with a set of S&S 585,andrews 50,SE 257 or woods 7H cams (among others),but any of these will work well with the 10.5-1 with no detionation (and I would either stay out of the throttle or change the cams now,detionation aint good for a motor,especially HD lower ends)
Old 05-12-2015, 07:08 AM
Hillsidecycle.com
Sponsor
And it'll eventually blast the top off the piston between the intake valve relief, and top ring land.
Scott
Old 05-12-2015, 02:22 PM
djl's Avatar
djl
djl is offline
Received 2,093 Likes on 1,538 Posts
Listen to Scott and Kirby. Been down that road with the SE204 with CCP near 200psi. No issues during the cooler months in south Texas but when July and August came around and ambient temps were hitting high 90s and 100*+, the ping started. Couldn't take enough timing out to eliminate the ping and still have a strong running motor. A cam change is in your future and I would not try to tune the motor in the current configuration. Change cams and then tune.
Old 05-12-2015, 03:58 PM
frankm205's Avatar
frankm205
6th Gear
Took a trip to the mechanic who hooked up the TTS tuner. A quick adjustment and I was off and running. No more pinging and the bike runs great. Temps here in NY have been well into the 80's which is when the pinging started. WE'll see what happens in the next few hundred miles.
Old 05-12-2015, 05:07 PM
prodrag1320
keep an eye on your plugs.little black specs on the porcelien is signs of detionation (acctully little pieces of your pistons)
Old 05-13-2015, 01:01 PM
Hillsidecycle.com
Sponsor
If it does not ping, it is not 10.5 cr.
Scott
Old 05-13-2015, 03:09 PM
frankm205's Avatar
frankm205
6th Gear
Here is the part # for the pistons
HARLEY-DAVIDSONŽ SCREAMIN’ EAGLEŽ PRO TWIN CAM HIGHCOMPRESSION CAST PISTON KITS* – 3-7/8" - 22661-99A
These high-compression 10.25:1 cast pistons are designed for use in a Twin Cam engine equipped with stock cylinder heads and 3-7/8" cylinders (1550). Piston kit includes rings, clips and pins. All EFI models require ECM calibration (priced separately).
Cams are se 204 part # 25149-00
Quick Reply: Engine pinging
