103 stage 4 install question
Old Aug 4, 2015 | 10:38 PM
mag540's Avatar
mag540
Stage III
Default 103 stage 4 install question
I am installing a stage 4 kit in my 2014 Street glide. The question i have is the kit has 2 sets of head gaskets. Neither have the same diameter fire ring and they are different thickness.
stock is measures 3.94" across the ring
option 1 part # 16787-99a
measures 3.94" and is .0055 thick
option 2 Part # 16775-99b
measures 3.84" and id .0055 thick as well.
So why did the include 2 different sets of head gaskets and what set do I use. If they were different thickness I would understand the option. I assume i go with the first option as it has a larger fire ring and the combustion chamber is slightly larger but the included install instructions do not speak of a gasket choice.
I prefer to keep it all Harley in an effort to kep compression at the advertised 10.5 : 1.
Thanks for any help
Old Aug 5, 2015 | 11:39 AM
djl's Avatar
djl
Not sure why two gaskets are in the pack but the change from A to B could be many things; change of supplier, elimination of o-ring at oil return, change of material, etc. As a Cometic user, I would not use either one. I would most likely be using a Cometic gasket that is .040" or .030" to improve squish.
Let me ask you a questions though. Why would you use the -99B at 3.84" when your cylinder bore is 3.875"?
Old Aug 6, 2015 | 12:58 PM
grbrown's Avatar
grbrown
If you read the instructions they tell you the head gasket is #16787-99a.
muskwa
Engine Mechanical Topics
Mar 7, 2018 07:21 AM
mag540
Aug 5, 2015 03:28 AM
palatium
Jul 18, 2010 09:38 AM
voodoodrug
Jul 8, 2010 10:27 AM
Sleeps In Trees
Exhaust System Topics
Jul 24, 2006 06:01 PM
