head gasket question
Old Jul 8, 2010 | 07:52 AM
voodoodrug's Avatar
voodoodrug
Default head gasket question
can I just/simply replace stock head gasket with a 0.03 cometic head gasket? been reading that this is a good thing to do. no head work,stock push rods.
Old Jul 8, 2010 | 08:00 AM
rmd's Avatar
rmd
So why will you do that?
Old Jul 8, 2010 | 08:12 AM
voodoodrug's Avatar
voodoodrug
replaceing 96 jugs with 103 and bolting on 255 cams.No head work except thinking alot about mcr holes drilled.
Read on hear that this adds a little compression and tightens it up a bit...a worth while thing to do while im in there but dont want to get over budget and too complicated at this point. Done a lot of searches and its mentioned alot.
Old Jul 8, 2010 | 08:42 AM
rmd's Avatar
rmd
I use 0.040 cometic gasket and it looks good
Old Jul 8, 2010 | 08:53 AM
mainshaft's Avatar
mainshaft
I would do it, and have done it twice in the last 8 months on my bikes. If your taking it apart I would go with the .030 gasket. My 2 cents.
Old Jul 8, 2010 | 09:12 AM
Lama's Avatar
Lama
If you want to do the 103" kit right, install the cylinders with pistons no rings, use a headbolt to secure the cylinder/piston down to the cases, put piston on TDC, use a micrometer to measure how far down in the hole the piston is (I find that most TC96 are near .008" in the hole), record this for front and rear cylinder. Write it on the jug with a black sharpie, as well as marking them FRONT and REAR.
Take both jugs to a machine shop, have them cut the BOTTOM of the cylinder with a lathe to remove the extra height.
Reinstall on bike, this time with piston rings, o-rings, etc.
Use a .030" Cometic MLS headgasket.
You will hav a perfect .030" squish, which will preclude you from having detonation (pinging).
Also, I highly reccomend you have your heads drilled for MCR.
You could also do alot better than 255 cams.
Old Jul 8, 2010 | 10:27 AM
voodoodrug's Avatar
voodoodrug
thanks all!
That answered alot of questions I had,problem is I keep wanting to get it too right and am haveing a problem knowing when to stop lol I will keep all this in mind and try to keep it simple this time.If it is not suitable for my needs will try something else next time.I might try this and talk to mechine shop and all. thanks again!!!
Road Star
May 15, 2017 07:05 PM
95 Ultra
EVO
Oct 24, 2012 08:06 PM
iknowyoueazyryder
Ironhead
Feb 18, 2008 05:25 PM
jakazz
Exhaust System Topics
Jul 2, 2007 10:05 AM
harris48cars
Mar 15, 2006 11:46 PM
