engine interchange
Old Jun 1, 2016 | 02:34 PM
Ratherberacin's Avatar
Ratherberacin
mdm, the "slight noise" is the slippers gone off the tensioners and metal on metal grinding. new to Harley. not new to mechanics.
Old Jun 1, 2016 | 03:58 PM
Lunchboxx's Avatar
Lunchboxx
You could just replace the shoes its not super hard or expensive. Is that the only issue?
Old Jun 1, 2016 | 04:18 PM
djl's Avatar
djl
Originally Posted by ratherbracin
i have a 06 road king that I bought as an insurance rebuilder. got it all fixed and I hear a slight engine noise.....cam chain tensioners are toast and the moron who owned it. (we will call him "just ride it") never did any maintenance on this poor bike. it has 40,000 miles and I am pretty sure its on its factory oil. but........he spent over $2000 on ***** g skull crap all over the bike. priorities!!! I am going to pitch that engine and get another drop in.
so rant over. what years can I interchange with this boat anchor? 2006 88" injected.
can I go a 96" without major drama?
my first Harley experience is going very poorly.
You bought the bike as an insurance rebuilder and are stunned that the "experience is going poorly" because you hear a "slight" engine noise?? wow, what a surprise that must have been.
The MoCo does have a "long block" program; a replacement for the "reman" program they used to offer. A 96" motor will not "drop in"; you need many different parts aside from the motor. I am betting all that is needed to put your "boat anchor" back in fighting condition is a cam chest and top end upgrade. If that motor is running, the cam chest damage is not catastrophic and that motor can be salvaged; much easier and cheaper than a replacement. Bore to 98", clean up the heads and deck about .025"-.030" ('06 heads flowed better than previous years), good SERDI valve job, new guide seals, use a .030" head gasket, keep the OEM cam plate, replace inner and outer cam bearings, replace the oil pump with a Daytona higher capacity pump, replace the tensioners with the CYCO shoes and throw in a set of S&S 583, Andrews 48 cams, S&S standard lifters and SE adjustable tapered pushrods, get her tuned and let her rip.
Have you opened the cam chest to take a look? Cut open an oil filter? Run a compression or leakdown test? These motors can actually take a lot of abuse; it might be worth saving; JMHO.....
Old Jun 1, 2016 | 04:24 PM
QC's Avatar
QC
Old Jun 1, 2016 | 06:29 PM
Ratherberacin
its getting torn down tomorrow and we will decide which way to go. I apologise for my rant. I know lots of Harley guys and probably 70% are like the guy who owned this bike. no maintenance, ride it and be shocked when it breaks.
me buying it assuming it was in mint shape was a foolish move. I should have known better as this isn't the first insurance claim vehicle I have bought. lol live and learn
ill fix it properly and the new owner will have a good bike. no more harley rebuilders
Old Jun 1, 2016 | 06:46 PM
Notgrownup's Avatar
Notgrownup
Check it out good... You not knowing what the previous owner did or didn't do makes it a crapshoot. But the flip side is it might just be the tensioners...good luck with it. I hope you can salvage it and maybe boost up the power with a set of cams and enjoy...
Old Jun 3, 2016 | 09:16 AM
Ratherberacin
took it to a really good Harley machanic and he tore it down. jumped to conclusions. oil pump is good, crank good, one cam has a tiny bit of the Parkerizing failing. filter cut open and is ok for metal. so the slipper failure is minimal and must have just occured. replacing cams, chain, pushrods, lifters adjusters ect and run it.
I can sell it knowing its not a pos.
Old Jun 3, 2016 | 09:27 AM
Notgrownup's Avatar
Notgrownup
Good, that will save you a lot of headhaches.
thoner7
Aug 15, 2017 12:38 PM
NickWlad
Jan 6, 2015 09:02 PM
FXD_noob
Jun 16, 2014 10:41 PM
Skygoose
Jan 10, 2011 06:14 PM
DDGLIDER
Exhaust System Topics
Oct 17, 2007 05:18 PM
